Require LonWorks shadow device object for Danfoss device with program ID 80:0:8:3c:a:84:4:11
  • Require LonWorks shadow device object for Danfoss device with program ID 80:0:8:3c:a:84:4:11
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • RyanSuar
    RyanSuar
‎2018-09-10 12:40 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:41 AM
TAC IA Series
I/A Series R2
The lonDanfoss module prior to version r2.301.529 does not have the shadow device object for Danfoss device with program ID 80:0:8:3c:a:84:4:11. Some NCIs cannot be read if a DynamicDevice is used.
The shadow device object for Danfoss device with program ID 80:0:8:3c:a:84:4:11 (VltFc100V121) is available in lonDanfoss JAR file version 2.301.529a. You can download the JAR file here.
This is also available in I/A Series R2 version r2.301.532.
Refer to How to install an I/A Series R2 JAR File for the procedure to install an updated JAR file to an I/A Series installation.
  • TAC IA Series
lonDanfoss-2.301.529a.zip
  • 8313
