Replace 7792 (7790) and 7793 (7790A) LIU with 7798C
  • Replace 7792 (7790) and 7793 (7790A) LIU with 7798C
  • AdamSteele
    AdamSteele
  • RobertAndriolo
    RobertAndriolo
  • Cody_Failinger
    Cody_Failinger
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
  • Tom_Poovey
    Tom_Poovey
  • CraigEl
    CraigEl
‎2020-10-20 06:44 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-07 10:58 PM
  • Separate a 7792 or 7793 into two 7798C
  • Split SAV files
TAC INET
  • I/NET Seven
  • 779x Controllers
Need to replace a 7792 or 7793 which has two station addresses and replace with two 7798C Controllers which have one station address
To split the required SAV Files:
  1. Download and Extract the attached SAV_Split_EXE.zip
  2. Make a backup of the I/NET Seven system using DBCreate.
  3. Perform Station Save to all the required controllers
  4. Copy the SAV files that need to be split to the same location where the ZIP file was extracted too in step 1.
  5. Run the SAV_Splt.exe
    1. The commands are showing the Sav_Splt.txt file contained within the ZIP file and shown below
Purpose:
Use this tool to create two 7798 SAV files from a dual-station 7793
SAV file.
Syntax:
Sav_Split.exe (with no parameters will check all save files in the current directory and split 2 station 7793s.)
Sav_Split.exe LLSS (where LL = Link and SS = Station)
Result:
The resulting files will be named DCULLSS-0.SAV and DCULLSS-1.SAV.
Rename these files appropriately to match the link and station of
the 7798 into which each will be loaded.
Example:
SavSplit.exe 0906
Results: DCU0906-0.SAV and DCU0906-1.SAV
Finally check the split files using the "Work Offline" mode within I/NET Workstation.
Any issues or additional questions please raise a case with your local support
For SAV file upgrade information see How to upgrade bin and SAV files in I/NET controllers.
  • TAC INET
SAV_Split_EXE.zip
Tags (6)
  • 15720
  • discontinuation
  • discontinued
  • replacement
  • RobertAndriolo20
  • SAV_Split
100% helpful (1/1)
