Remove Server information shown in WorkStation drop down list
  • Remove Server information shown in WorkStation drop down list
‎2018-09-11 08:44 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:36 AM
Building Operation WorkStation
Warning
Building Operation WorkStation 'caches' user customization's including the server names / IP addresses that it has previously successfully logged on to.
Two tools are available on the Community that can assist in this process. Refer to the details and instructions for both on the Community.
  • SBO Reset WorkStation Login
  • SBO WorkStation Favorites
To manually delete the file containing the servers list (among other information), navigate to and delete the file.
The location and file name depends on the installed version of WorkStation.
  • Version 1.3
    C:\Users\%username%\AppData\Roaming\Schneider Electric\Workstation\TAC.ClientUserProfile.bin
  • Version 1.4 and 1.5
    C:\Users\%username%\AppData\Roaming\Schneider Electric StruxureWare\Building Operation\WorkStation\TAC.ClientUserProfile.bin
  • Versions between 1.6 and 1.9
    C:\Users\%username%\AppData\Roaming\Schneider Electric StruxureWare\Building Operation\WorkStation\SBO.ClientUserProfile.bin
  • Version 2.0 and above
    When hovering over a server in the drop down list, a trash can appears at the right side that allows the server to be deleted from the list:
    WorkStation 2.0 and aboveWorkStation 2.0 and aboveWorkStation 2.0 and aboveWorkStation 2.0 and above
    Alternatively the path to the file is:
    C:\Users\%username%\AppData\Roaming\Schneider Electric EcoStruxureWare\Building Operation\WorkStation\SBO.ClientUserProfile.bin
Next time you run WorkStation again, a new user profile file will be created.
Note: All IP addresses will be cleared and you will lose settings such as column widths and similar user customization's.
Tags (2)
  • 19107
  • RobertAndriolo19
