Microsoft.Net Framework and Webstation 5.1.9
  • Microsoft.Net Framework and Webstation 5.1.9
  • RobertAndriolo
    RobertAndriolo
  • Jonas_Brissman
    Jonas_Brissman
  • CraigEl
    CraigEl
‎2018-09-07 06:40 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 11:15 PM
What version of Microsoft.Net Framework and ASP.NET is used by Webstation 5.1.9?
TAC Vista
Vista Webstation 5.1.9
ASP.NET is a web application framework developed and marketed by Microsoft to allow programmers to build dynamic web sites, web applications and web services. TAC Vista Webstation is developed using ASP.NET, which is a part of the Microsoft.Net Framework.
TAC Vista Webstation uses Microsoft.Net Framework 4 and ASP.NET 4.
For details on additional Vista versions and the .NET framework and ASP.NET versions required please consult the compatibility matrix in the Supported version of .NET framework and ASP.NET for Vista software.
Tags (3)
  • 4665
  • dotnet
  • JonasBrissman20
100% helpful (1/1)
