Error "communication failure due to routing device not available" when viewing BACnet controllers or objects
  • Error "communication failure due to routing device not available" when viewing BACnet controllers or objects
  • AdamSteele
    AdamSteele
  • Alan_Wood
    Alan_Wood
  • CraigEl
    CraigEl
‎2018-09-10 11:23 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 06:06 PM
"Communication failure due to routing device not available" errors when trying to view BACnet controllers or the objects they contain.
Andover Continuum
Continuum v1.74 and above.
The Cyberstation is unable to route to the desired device(s). This can occur due to changes in the network, network settings, or blocking software on the PC.
Check that the IP settings of all devices are configured so they can see each other. Specifically that the subnet mask configured for each device allows them to be seen on the same logical network.
Also see the following articles:
  • Communication failure due to routing device not available
  • Eaton IP BACnet Lighting Panels go offline with error "Communications failure due to routing device ...
  • Simple BBMD setup
  • 7980
