Ensure proper network biasing on a BACnet MS/TP network
  • Ensure proper network biasing on a BACnet MS/TP network
  • Cody_Failinger
    Cody_Failinger
  • RyanSuar
    RyanSuar
  • CraigEl
    CraigEl
‎2018-09-07 04:14 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 12:27 AM
All MNB devices under the UNC-520 are offline and not communicating.
TAC IA Series
MNB controllers connected to UNC-520 RS-485 port
The MNB-300 and MNB-1000 bias resistors (jumpers label 'MS BIAS') should be disabled by default as indicated in their respective documentation. However, it appears that the MNB-1000 bias resistors are coming enabled.
As a requirement of EIA-485 network topology, an MS/TP network must have at least one set, and no more than two sets, of network bias resistors on each MS/TP network segment, preferably (but not required to be) in the middle of the segment. In MS/TP networks, this requires an MNB-300, MNB-1000, or UNC-520 with the appropriate jumper settings.
UNC-520 bias resistors on its RS-485 ports are enabled by default.
Ensure that no more than 2 sets of bias are enabled on the MS/TP segment. The bias on the UNC-520 is enabled by default and as such, there should not be more than 1 MNB controller with its bias resistors set enabled on the BACnet MS/TP segment.
Refer to page 71 of the document ‘F-27360 IA Series Micronet BACnet Wiring, Networking and Best Practices Guide’ for further information.
Also refer to Enabling MSTP bias resistors on a MNB-1000.
  • TAC IA Series
  • 4353
0% helpful (0/1)
