Enabling MSTP bias resistors on a MNB-1000
  • Enabling MSTP bias resistors on a MNB-1000
  • Cody_Failinger
    Cody_Failinger
  • SESA113595
    SESA113595
‎2018-09-06 02:57 PM
When should the MSTP bias resistors be enabled on a MNB-1000?
TAC IA Series
BACnet /MSTP trunk under an MNB-1000
RS-485 biasing rules apply to BACnet / MSTP
An MSTP network requires at least one set of bias resistors but no more than two sets. If a UNC device exists on the network it will provide one set of resistors.  No others are needed. If one or more MNB-1000s are on the network, enable only one set of bias resistors.
  • TAC IA Series
  • 2669
