Compatibility of w TP/FT -10 channels with SE7000 series controllers with LonWorks communications
  • Compatibility of w TP/FT -10 channels with SE7000 series controllers with LonWorks communications
  • Ramaaly
    Ramaaly
  • RyanSuar
    RyanSuar
  • RobertAndriolo
    RobertAndriolo
‎2018-09-11 06:00 AM
Last Updated: Lt. Commander Ramaaly Lt. Commander ‎2022-04-05 08:40 AM
The client is inquiring if SE7000 series controllers with LonWorks communications are compatible with TP/FT -10 channels
EcoStruxure Building Operation, EcoStruxure Building Expert
  • Building Operation Workstation
  • Building Operation Automation Server
  • SSL SE7000
The datasheet indicate network compatibility with Echelon LonTalk but there is no mention of the compatibility with TP/FT-10 channels / networks. This may be unclear to some.
The SE7000 series is compatible with LonWorks TP/FT-10 channels. Refer to the datasheet for 14240R which is the free topology transceiver used in the SE7000.
capacitors, LPT-10 Link Power Transceivers
Free Topology Transceivers, and, with suitable DC blocking
FT 3120 / 3150 s mart Transceivers, FTT-10 and/or FTT-10A
Labels (2)
  • EcoStruxure Building Expert
  • Field Devices
Tags (5)
  • 14383
  • RamaAly22
  • se7200
  • se7300
  • se7600
