Cannot edit the graphic because the Graphics Editor has lost connection with the server
  • Cannot edit the graphic because the Graphics Editor has lost connection with the server
  • CraigEl
    CraigEl
  • Cody_Failinger
    Cody_Failinger
  • Benji
    Benji
  • Ramaaly
    Ramaaly
  • RobertAndriolo
    RobertAndriolo
  • Gary
    Gary
‎2018-09-11 07:51 AM
Last Updated: Administrator CraigEl Administrator ‎2023-09-13 05:17 PM
When attempting to edit a graphic on an SBO/EBO ES or AS the Graphics Editor, Function Block Editor or Script Editor reports it has lost connection.
  • Building Operation Workstation
  • Building Operation Automation Server Premium
  • A second instance of the workstation is running on the same computer
  • The firewall is blocking the connection.
  • The password was recently changed during the same session
  • Workstation is connected via HTTPS but there is no valid certificate
Solution 1
If using Remote Desktop (RDP) to access the SBO/EBO ES remotely, a second instance of the workstation could be initiated.
Close the workstation on both the remote connection and at the SBO/EBO ES.
Then open the workstation either at the SBO/EBO ES or via remote connection, not both.
Solution 2
Check if the firewall has been enabled while logged in to the SBO/EBO ES or AS, and disable the firewall
Here is an example for McAfee
Solution 3
Make sure the network information (such as gateway) for the PC is entered correctly.
Solution 4
If you just changed the password of the logged in user, log out and in again
Solution 5
Workstation is connected via HTTPS but there is no valid certificate. Ensure that certificates are installed and trusted on the workstation/server so that no certificate warnings are received or use HTTP to connect to the server.
Solution 6
Update the Certificate Revocation List as described in First time a TGML graphic is opened after logging in it takes a long time for the graphic to load.
Tags (4)
  • 18097
  • CraigEllis23
  • exit
  • RamaAly23
100% helpful (9/9)
