Automation Server Password policy configuration grayed out
  • Automation Server Password policy configuration grayed out
  • RandyDavis
    RandyDavis
  • Reza
    Reza
  • Cody_Failinger
    Cody_Failinger
  • JohnBoehmer
    JohnBoehmer
  • Sacco
    Sacco
‎2018-09-10 01:56 PM
Last Updated: Guinan RandyDavis Guinan ‎2022-06-01 12:10 PM
The automation server password policy is grayed out making it unavailable to make configuration changes.
  • Building Operation Workstation
  • Building Operation Automation Server Premium
When an Automation Server is attached to an Enterprise Server, all of the password policy configurations are inherited from the enterprise server. Therefore the AS settings cannot be changed.
The password policies of the Automation Server must be administered from the ES when it is connected to an Enterprise Server.
In order to make changes to the password policy settings in the Automation Server directly, it must be detached from the Enterprise Server.
Note:
For EBO V 1.9.X and lower, the password policy settings can be located under Control Panel > Security and Communication > Security settings area.
For EBO 2.0.X and higher, the password policy settings can be located under Control Panel > Security and Communication > Password policy.
Tags (7)
  • 18479
  • credentials
  • grey
  • greyed
  • RezaAmirzadeh22
  • strength
  • strong
100% helpful (4/4)
