Access Expert EP1501 Controller Configuration
  • Access Expert EP1501 Controller Configuration
  • RandyDavis
    RandyDavis
  • Cody_Failinger
    Cody_Failinger
  • Roger_Bently
    Roger_Bently
  • Derrick_Ratliff
    Derrick_Ratliff
  • sesa119747
    sesa119747
‎2018-09-06 08:35 AM
Last Updated: Guinan RandyDavis Guinan ‎2019-11-26 12:24 PM
Using an EP1501 as a controller and unable to add reader one.
Access Expert
  • Access Expert
  • Server 2012R2 and above
Using an EP1501 as a controller as well as a card reader controller.
To resolve the issue, please follow the steps listed:
  1. Wire the RS-485 bus to reader port 1, Clock and Data
  2. Wire the reader being used on port 2
  3. When programming the reader on the device, it needs to be added as Reader 1
  4. The Door Address needs to be set as 0 as well
  • EcoStruxure Access Expert
Tags (2)
  • 18966
  • RogerBently19
