Access Expert Cardholder Nickname field showing Nickname text on badges instead of data entered
  • Access Expert Cardholder Nickname field showing Nickname text on badges instead of data entered
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • Taylor_Leach
    Taylor_Leach
  • Alan_Wood
    Alan_Wood
‎2018-09-10 10:10 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-12 12:00 AM
Cardholder Nickname field is showing "Nickname" instead of data entered into 2nd cardholder when previewing badges.
EcoStruxure Access Expert
  • Badge preview
  • Nickname field
In Access Expert the cardholder Nickname field must have unique data within the database
The Nickname field must have unique data for all card holders within an Access Expert database.
Do not enter 'admin' in that field for one card holder and again for another cardholder.
What is the intended use for this field? In one case, the intended use was for Job Title and a better solution was to create a Custom Attribute of Job Title instead and to place that field in the badge layout. That way the field can have the same data in it for multiple cardholders.
  • EcoStruxure Access Expert
Tags (2)
  • 19801
  • v2
