121 controller when setup for 2 pipe system will not heat or cool
  • 121 controller when setup for 2 pipe system will not heat or cool
  • Cody_Failinger
    Cody_Failinger
  • RobertAndriolo
    RobertAndriolo
  • CraigEl
    CraigEl
  • PeterLarsen
    PeterLarsen
‎2018-09-11 06:18 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:11 PM
A Xenta 121-FC controller setup as a 2 pipe system will not heat or cool even though the terminal load is showing a demand.
TAC Vista
Xenta 121-FC
The Xenta 121-FC does not have a water temperature sensor wired into the device
For this functionality to work automatically, a water temperature sensor must be wired into the U1 terminal on the FC-121.
The other alternative is to set the supply temperature via the SNVT nviSourceTemp. This can be done from a supervisory system that is feeding the water to the 121-FC.
To use the SNVT nviSourceTemp as a solution the correct heartbeat will be require to be set in the 121-FC.
Values sent from a Xenta 121 FC/HP via SNVT bindings are not making it to the receiving controller is a link on how to set that up.
  • 14789
