Hide HMI Screens at Run Time
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Hide HMI Screens at Run Time
Charles_Murison
Picard Charles_Murison Picard
490
Ramasamy_N
Captain Ramasamy_N Captain
115
Mehran_Mehrnia
Captain Mehran_Mehrnia Captain
92
Robert_Lee
Admiral Robert_Lee Admiral
92
ShawnPickett
ShawnPickett
Cadet
Posted: ‎2024-04-18 08:49 AM
640
I'm using Vijeo Designer V6.2 to program an HMIGTO3510. I have 9 base panels, each with a Previous and Next button with a Switch Setting to navigate to another panel based on Panel ID.
I'm looking for a way to hide two of the panels at run time based on a bool variable set from an external MODBUS address. Since base panels don't have a Visibility property, I thought it might be possible to script a Panel Action to change the panel ID used in the Switch Settings but I have found no information on how to write a script to do this.
Is there a way to effectively hide base panels at run time based on a bool variable? Is there another way to sequentially navigate between panels using a Previous and Next button that allows for skipping certain panels based on a bool variable?
Shawn...
Ramasamy_N
Captain
Posted: ‎2025-01-07 07:05 AM
Please post this query in correct channel or connect the technical support team.
Ramasamy_N
Captain
This is a heading
