Cannot uninstall PowerChute Personal Edition 2.2 on Windows 7
  • Cannot uninstall PowerChute Personal Edition 2.2 on Windows 7
2151
116
83
Posted: ‎2021-06-30 07:02 PM . Last Modified: ‎2024-03-19 11:57 PM
21066
I tried to uninstall PowerChute Personal Edition 2.2 on Windows 7. The Windows installer log file contains this text:
Action start 15:54:18: CheckRequiredFile.
DEBUG: Error 2738: Could not access VBScript runtime for custom action
MSI (s) (34:24) [15:54:28:172]: Product: APC PowerChute Personal Edition v2.2 -- The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738. The arguments are: , ,
MSI (c) (DC:94) [15:54:18:291]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
Action ended 15:54:28: CheckRequiredFile. Return value 3.
Could you e-mail me the instructions for manually removing PowerChute?
  • PowerChute
  • problem
  • software
  • uninstall
  • windows
Replies 113
  • « Previous
    • 1
    • 2
    • 3
  • Next »
Posted: ‎2021-06-30 07:05 PM . Last Modified: ‎2024-03-19 11:54 PM
Please send me the uninstall instruction. Thanks
Done.
Hello, I'm unable to uninstall PowerChute 3.0.0.1 on my Windows 7 Home system. Can you send to me on MP the uninstall procedure ? Thank you.
Sent
The registry procedure send to me didn't work for my system (or my problem...).
A PM has been sent to itsonlyme
After following the guide, have you tried restarting the PC or running a registry cleaner?
can you send it to me as well?
Posted: ‎2021-06-30 07:06 PM . Last Modified: ‎2024-03-19 11:54 PM
can any one plz help me with this?
Message was edited by: mail2vrp
A PM with instructions has been sent to Uninstall
Hi, can I have the instruction too? Many thanks in advance!
PM sent to acwc65
A PM has been sent to edrud, sma and ForeverNewbie.
Hello, I'm unable to uninstall PowerChute 3.0.0.1 on my Windows 7.
I cannot upgrade to PowerChute 3.0.2 too.
"Please check the USB connectivity between your PC and UPS ....."
Thank you.
Posted: ‎2021-06-30 07:06 PM . Last Modified: ‎2024-03-19 11:53 PM
tomik installation, reinstallation of PCPE requires that the USB cable is attached from the PC to the UPS and the software should show that they are communicating or the UPS has been detected by your computer.  If the computer fails to detect the UPS then it is one of the possible issue why the software installation/uninstallation wouldn't complete.  I have sent you also the guide on your Inbox.
I went throught steps You send me in fers e-mail. Then I restarted PC and
now there is no old PowerChute program installed in my PC. But installation
of newest version (3.0.2) still failed with in same point.
I have connected UPS to PC but computer fails to detect UPC ...
thanks for response
Dan Tomik
I would also like instructions. Been trying to upgrade and uninstall all day
Can someone send me the instructions on uninstalling from win xp pro sp3 I cannot install new powerchute because it says the old software has to be removed. it was removed but still get same message.
Can you email me instruction on how to remove PowerChute Personal Edition 2.0 on Windows XP SP3?
Thanks much
tomik in your case we would need to find out why is the PC not communicating with the UPS.  This would involve making sure that we have the correct cable connected, reseating the USB cable, trying a different USB cable.  We would also want to check the Device Manager to find out it the UPS gets listed on it either under Battery or Human Interface Device.  We would also try installing the UPS on a different computer and try it from there.
We have created a new public knowledge base that can serve as your guide on how to manually uninstall the PowerChute Personal Edition.  Please use our APC Knowledgebase by using this link -- http://www.apc.com/site/support/index.cfm/faq/index.cfm and then search for FA159949.
I have been reading post on this thread, I see a lot of people looking to uninstall software that I am looking to install.
What is the main issue and why is everyone so eager to uninstall this software? I only ask so that I can make a decision to install it or not. - Thank you
Posted: ‎2021-06-30 07:07 PM . Last Modified: ‎2024-03-19 11:53 PM
I just try to reinstall APC driver. Now when I disconnect UPS - APC UPS
disappear from Device Manager. When I connect UPS then APC UPS appear again
in Device Manager.
But installation PowerChute crash again - as You can see on attached
pictures
I try UPS to power off and on, disable antivirus, disconnect other USB
devices and restart PC many time - but nothing help.
I have Windows 7 Unlimited (Czech version) with last updates.
thanks for Your response
Dan Tomik
Dan,
When you look in the Device Manager under Human Interface Devices you should see American Power Conversion USB UPS
When you open that does the Location display the proper UPS model and if so what is the model UPS?
I aslo need this. Coul you sent it to me, please?
But I have a question? Why keep it a secret and not post it here?
I need the instructions as well
I have the same problem,
Can you share the solution instead of sending people personal messages?
//Klaus Jacobsen
The one that I sent can be used on both Windowss 7 and Vista
Need instructions to uninstall for Win 7 - version 2.11
Message was edited by: Uninstall
JonPro or anyone, I can't remove PowerChute Personal Edition 2.0 on Win XP Pro SP 3.
Would appreciate the manual uninstall instructions.
Can someone please help by PMing the instructions? Thanks.
Hello, I had a back-ups 750 on my system with PCPE installed (Win 7 64b). I now have a SMART-UPS 1000 and would like to have the personal edition software removed please.
Can I get a copy of those instructions?
Thanks in advance.
A PM has been sent to tinker3433.
I need the instructions too
Please email me the uninstall instructions. I'm trying to uninstall PowerChute Personl 3.0 on Win7 64bit
Good day MNSurfer,
  I've sent you a direct message with the uninstall instructions.
Posted: ‎2021-06-30 07:07 PM . Last Modified: ‎2024-03-19 11:52 PM
Can you also send me the uninstall instructions for power chute from windows server 2008..
Thanks,E
I would also need the instructions for uninstalling APC. Yesterday I updated from 3.0.0.1 to the latest, and got a BSOD. I would suggest to make this a public thread instead of requiring a PM. Thanks in advance.
Posted: ‎2021-06-30 07:08 PM . Last Modified: ‎2024-03-19 11:52 PM
A PM has been sent to Mitchel and luis.gomez.
A PM has been sent to Gener.
I also need uninstall instructions for Win7-64 - trying to upgrade to v3.0, and have the same error - 2738.
Please send an eMail - Thank you !!!
@BarnacleBill Anychance of sending us the instructions to manually remove Powerchute Personal Edition from an SBS 2008 box?  Just wondered if you managed to remove it successfully? Thanks in advance.
I have sent a Direct Message to your Inbox mctosh.  Kindly follow the steps and let us know the outcome.
Since so many people are requesting this information why isn't the link or process just posted. It appears to be helpful for many, if it was posted they could reference it without having to wait for the email.
I also would like this information.
Thanks for your email and instructions Jon P, I have no problem myself as my APC UPS is an old and out dated model, but it still works fine.
I was just interested in the removal instructions for anybody else I come in contact with that may have the problem.
Peter
ALL EMAIL SCANNED USING NOD32 V5.2.9.1
Sent: Tuesday, March 05, 2013 1:06 AM
To: subyroo
Subject: You have been mentioned by Jon P. in Re: Cannot uninstall PowerChute Personal Edition 2.2 on Windows 7 in APC Community Homepage
by Jon P. in Re: Cannot uninstall PowerChute Personal Edition 2.2 on Windows 7 in APC Community Homepage - View Jon P.'s reference to you
May I please get the instructions for removal as well?
ams001_apc
ams001_apc
Cadet
I need the instructions as well. I get error code 2738 trying to uninstall. My APC died so I no longer need this. Running Win7 x64
Message was edited by: ams001
I agree 100% cpupro.
I do understand where you are coming from cpupro, unfortunately this is a control document that gets to be updated from time-to-time and we need to be sure that the updates are kept in a single place.  It involves certain steps that if done incorrectly would result into having a corrupted OS.  For your perusal and to subyroo, I will be sending a direct message with the instructions on it.
Please send me the manual uninstall instructions for PowerChute Personal Edition 3.x too.
Something went wrong during an upgrade to the latest version and I am stuck in an unrecoverable state. I can't uninstall the old version (it still appears listed as an installed program) because the uninstaller runs but claims an necessary component isn't present, but doesn't say which or what. Nor can I install a new version because the installer reports the same uninformative message.
I would like to laboriously remove all vestiges of PCPE and reach a state from which I can install the latest.
Frank.
I also need instructions to uninstall Powerchute Personal Edition 3.0.2
I'm using Win7 Pro 32 bit.
  • « Previous
    • 1
    • 2
    • 3
  • Next »
