84606members
353882posts
BR1500G-IN Not Turning On.
kizek212_apc
289
This was originally posted on APC forums on 6/15/2013
First of all, greeting to everyone.
I've recently bought this BR1500G-IN UPS. It was working perfectly fine for 3 days.  I turned it on today, but all of a sudden it turned off automatically. Before it turned off I heard a 'click' sound.. like circuit breaker tripping. I suspected that that it might've tripped so I tried to reset the circuit breaker switch at the back. But the the circuit breaker switch was at normal (seated) position.. it wasn't sticking out like it happens when it actually trips.
I pressed the reset button nevertheless but to no avail. The UPS wont turn on. I removed and reseated the battery, held down the power button for 10-20 seconds.. nothing worked.
Any suggestions to solve this problem?
kizek212_apc
Re: BR1500G-IN Not Turning On.
This was originally posted on APC forums on 6/16/2013
As I've stated above, the circuit breaker reset switch is not sticking out like it is in my Back-UPS RS1100, which is working fine. So has the circuit breaker actually tripped and that's why it is in seated position??
I pushed it many times but it doesn't work.
Techsplosion_apc
This was originally posted on APC forums on 6/17/2013
If you plug it into an outlet, does it pass power from the outlets labeled as "surge only"?
2 Replies 2
kizek212_apc
Techsplosion_apc
