Posted: 2021-06-29 12:22 AM . Last Modified: 2024-03-14 12:50 AM
I have a device that has a 6-20P plug (not the twist-lock L6-20P) that's current plugged into a 6-20R receptacle on the wall. This is in a business and I'm not sure if the power source is 208 three phase, or 240 single phase. All I know is that it's 6-20. I need to purchase a UPS to protect the device from brown-outs and surges.
I don't see any 230/240V APC models for the US, only 208V models with L6-20. If business's power source is 240 single/split phase, will the APC UPS's rated at 208V work? If this is the case then I will hire an electrician to make converter plugs to convert 6-20 to L6-20 so the UPS will plug into the receptacle and the device can plug into the UPS. Thanks
Posted: 2021-06-29 12:23 AM . Last Modified: 2024-03-14 12:49 AM
I found converter plugs online so physically I know I can do it, I guess I'm just curious if there are any APC UPS's that will work with 240V split phase, which is pretty much what every american household has coming into it...
http://www.stayonline.com/detail.aspx?ID=8988
http://www.stayonline.com/detail.aspx?ID=11070
Posted: 2021-06-29 12:23 AM . Last Modified: 2024-03-14 12:50 AM
Oh..
SURTD3000XLT
Nominal Output Voltage 208V
Output Voltage Note Configurable for 208 or 240 nominal output voltage
Nominal Input Voltage 208V
Input Connections NEMA L6-30P
Other Input Voltages 240
Thanks for steering me in the right direction... I think that was what I was looking for.
Brian,
The SURTD3000RMXL3U can be configured as 240 Volts. There is also a backlpane option for this UPS with 2 X 6-20 outlets.
[SURTD3000RMXL3U |www.apc.com/products/resource/include/techspec_index.cfm?base_sku=SURTD3000RMXLT3U&tab=Options&total...]
[SURT011|www.apc.com/products/resource/include/techspec_index.cfm?base_sku=SURT011]
The Symmetra LX will do 240/120.
