"The application was not able to load" after updating firmware
  • "The application was not able to load" after updating firmware
Posted: ‎2021-07-08 12:19 AM . Last Modified: ‎2024-02-29 11:14 PM
1217
I did update firmware on my APC Symmetra LX 12kVA (from Windows 8.1) and now I can't use web interface because of an error:
"The application was not able to load".
On telnet I don't see any error messages to.
What can/should I do?
This is About System output:
About System
Model Number : AP9619
Serial Number : ZA0705014103
Manufacture Date : 02/01/2007
Hardware Revision : A10
MAC Address : 00 C0 B7 2E 7B FC
Flash Type : AMD A29DL322DB
Press to continue...
Module Information
Description : Network Management Card AOS
Name : aos Type : APC OS
Version : 373 Sector : 16
Date : 02/02/2010 Time : 17:05:14
CRC16 : B630
Version : 373 Sector : 47
CRC16 : B630
------- System ----------------------------------------------------------------
Terry_Kennedy_apc
Commander Terry_Kennedy_apc
Commander
Somehow you ended up with 2 copies of the AOS and no APP on there. I'd suggest using the updater that comes bundled in the firmware download from APC to perform the update, as it avoids this issue. If you have the APP file somewhere and can't use the updater, you should just be able to FTP the APP to the card and wait for it to reboot. At that point, you should be able to use the web interface again.
Make sure you are installing the correct APP for your device - in your case, I believe it is apc_hw02_sy_372.bin.
Terry_Kennedy_apc
Commander
Thank you very very much)
Terry_Kennedy_apc
Commander
Glad to have been of help!
