"System Network Interface coldstarted." listed in logs but no reason for loss of power
Send InviteCancel
Posted: 2021-06-2807:36 AM. Last Modified: 2024-03-1812:19 AM
Hi Guys,
I see this entry in my logs and, on all my equipment checked thus far I see an uptime that marries to this event. I however see no events relating to battery usage nor do I see any reduction in charge over this time. A previous event shows on and off battery power and my monitoring system shows a drop in charge during this time.
Can anyone explain this? What should I see in the logs from a front panel shutdown / a.n.other event that could cause this?
Snippets from event log follow
Coldstart event, total power loss to all equipment attached, no reason in the logs:
03/07/2018 22:01:08 Device UPS: Restored the local network management interface-to-UPS communication. 0x0101
03/07/2018 22:00:58 System Network service started. IPv6 address y::y:y:y:y assigned by link-local autoconfiguration. 0x0007
03/07/2018 22:00:54 System Network service started. System IP is x.x.x.x from manually configured settings. 0x0007
03/07/2018 22:00:38 System Network Interface coldstarted. 0x000
Example from prior power fluctuation event:
03/06/2018 16:05:55 Device UPS: No longer on battery power. 0x010A
03/06/2018 16:05:54 Device UPS: On battery power in response to rapid change of input. 0x0109
