UPS Switches off after self-test
  • UPS Switches off after self-test
Posted: ‎2021-06-29 04:01 AM . Last Modified: ‎2024-03-13 01:54 AM
1008
We have an APC Smart-UPS 3000 and over the weekend it has switched itself off & shows no signs of coming back to life.
The symptoms are that when you run the self-test, the battery indicator goes to full and the green online indicator flashes for a second, the battery in use indicator (orange) lights for a moment, then one or more of the battery fault, over voltage, under voltage lights flashes on very quickly and it switches itself off completely with a clunk.
I have tried re-setting the UPS by disconnecting all load and mains power and holding the off button until it clicks ... the UPS continues to misbehave.
After removal of the battery pack, I have found that each of the batteries is individually showing a voltage output (not under load) of between 13.47 & 13.52 Volts.
Message was edited by: alain
Posted: ‎2021-06-29 04:01 AM . Last Modified: ‎2024-03-13 01:53 AM
No beeps to speak of, when you first press the test button there is a chirp-chirp, then the sound of the relays cutting in & the coils in the transformers energising, then it switches itself off with no lights at all visible, however there is a slight 50Hz hum coming from the unit.
Model No: SUA3000RMI2U
Serial No: JS0702024443
What is the model and serial # of this UPS? You should this info on a white sticker on the back of the UPS. So the UPS is not turning on at all? Any leds, beeps, noise when pressing the power button?
