SmartUps 30kVA In bypass
  • SmartUps 30kVA In bypass
Posted: ‎2021-06-28 05:14 AM . Last Modified: ‎2024-03-18 03:40 AM
1352
I have a SmartUPS 30kVA and 3 power sources (1 mains, 1 500kVA day generator and 1 45kVA night generator). To comand the changeover i have 2 automatic transfer switchs.
The UPS was installed 1 week ago and after a changeover it goes to bypass mode with the information In bypass in response to an internal hardware fault.
After i restart the UPS it works fine.
Some useful information:
About UPS
Model: Smart-UPS VT 30 kVA
Serial Number: PS1536230382
Firmware Revision: 909.0718.I
Manufacture Date: 09/03/15
Status
Last Battery Transfer: Due to software command or UPS's test control
Internal Temperature: 30.0°C
Runtime Remaining: 27hr 11min
Power Phase L1 Phase L2 Phase L3
Input Voltage: 215.0 VAC 215.6 VAC 216.3 VAC
Bypass Input Voltage: 215.9 VAC 214.9 VAC 216.0 VAC
Output Voltage: 219.7 VAC 219.1 VAC 219.3 VAC
Current: 00.00 Amps 00.00 Amps 00.00 Amps
Input Frequency: 50.02 Hz
Load Phase L1 Phase L2 Phase L3
Output Load: 000.3 kVA 000.1 kVA 000.0 kVA
Output Percent Load: 003 %kVA 001 %kVA 000 %kVA
Output Percent Power: 002 %Watts 000 %Watts 000 %Watts
Output Current: 0001 Amps 0000 Amps 0000 Amps
Output Frequency: 50.21 Hz
Battery
Capacity: 98.7 %
Nominal Battery Voltage: 192.0 VDC
Actual Battery Bus Voltage: 202.6 VDC
Battery Current: -0001.0 Amps
External Battery Cabinet Rating: 0000
Batteries: 12
Bad Batteries: 0
Intelligence Module
Firmware Revision: 07.18
Hardware Revision: 1
m state: 09 02 02 02000038 00000000 00000001 03
Can someone help me?
Nelson
Hi jon,
Thanks for the fast response.
Unfortunately im in africa and i can't contact the number ou gave me. Is there any international number? Or something i can do to try and diagnose what's wrong with my ups?
Nelson
Hi jon,
Nelson
