Posted: 2021-06-30 08:07 PM . Last Modified: 2024-03-07 12:34 AM
Hi All,
I have a Smart UPS 700 connected via a Smart Cable (serial) to a Vista workstation which is running Powerchute BE 9. All is good.
I would like to change the connection to a network connection. I understand that APC sell a Management Card that fits into the UPS.
I am very impressed with Powerchute BE 9. I am only using the Agent. Would I lose any functionality using a Management Card, would I need different software and/or would I need to install the Powerchute BE 9 Server?
Please could you tell me which card I should buy and how do I stand re. APC software?..
Thanks as always,
Jon
hi, you can use either AP9630, AP9631, or AP9618 -> http://www.apc.com/products/family/index.cfm?id=98
The NMC has a lot more capability than the PCBE 9. I suggest going to http://testdrive.apc.com where you can log in to a live card and investigate the interface for yourself. For graceful shutdown, an NMC utilizes [Powerchute Network Shutdown (free)|http://www.apc.com/products/family/index.cfm?id=127] to gracefully shutdown the attached computers/servers over the network, rather than a serial or USB cable.
these white papers may explain how things work:
http://www.apcmedia.com/salestools/TDOY-5UQVBV_R2_EN.pdf
http://www.apcmedia.com/salestools/BKIR-6DZPTG_R0_EN.pdf
http://www.apcmedia.com/salestools/SJHN-7APFKK_R0_EN.pdf
hope that helps!
thanks Jon for the kind comments. we surely appreciate the feedback. let us know if you need anything else.
hope that helps!
Thank you for your comprehensive reply which has set me straight once again.
I rather suspect I now have all the information I shall be needing, and may not be back to this forum for quite some time.
I am very impressed by the wealth of knowledge and friendly support provided by this forum.
I would never hesitate to buy another APC UPS and shall recommend APC at every opportunity.
Kindest regards,
Jon
