Posted: 2021-06-30 10:40 PM . Last Modified: 2024-03-06 10:45 PM
I am facing problem with SRCPM6KI. When I try to turn ON inverter all tests(frequency out 50Hz,input 230 50Hz,Rectifier OK, Charger OK, Battery OK, DC Bus OK, Inverter Test OK) passed but at the end when UPS self test started red warning light lit with beep sound and showing shutdown due to 016 DC Bus low. Secondly I want to download its logs from UPS brain. NMC not installed in this unit. Kindly help to resolve the issue.
Mukhtar
Problem solved pls give me solution i am facing
It would be beneficial for you to contact local technical support concerning this issue. Contact information can be found at this link http://www.apc.com/site/support/index.cfm/contact-information/
OK. Agreed. But just for information can we download event logs. And is there any calibration parameters of this UPS
Mukhtar
