  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
SUOL2000XLI - Overheat
  • Communities
  • Re: SUOL2000XLI - Overheat
  • Subscribe to RSS Feed
5026
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
DJPT_apc
Crewman DJPT_apc
Posted: ‎2021-07-07 11:27 PM
303
Share
This was originally posted on APC forums on 8/20/2015
Hello
We have an APC Smart-UPS On-Line 2000, model SUOL2000XLI.
Please can anyone confirm if this unit has an overheat protection function at all, ie if it overheats will it shut itself off or will there be an audible alarm?
  • 2000
  • apc
  • on-line
  • overheat
  • smart-ups
  • suol2000xli
Share
Terry_Kennedy_apc
Commander Terry_Kennedy_apc
Share
In the specific case of thermal runaway in the batteries, there isn't a lot that the UPS can do to stop the process and it may not even detect the situation, as can be seen from the difficulty in removing swelled-up / burst batteries from a UPS. In severe cases, it may take an extended period of time after the batteries are disconnected and electrically isolated for them to cool down enough for them to be safely removed - on a Matrix UPS with XR battery packs I had to wait nearly a whole day for things to cool down enough to be able to remove the batteries, and they were still quite warm to the touch.
Fortunately, the VRLA type batteries used in UPS systems don't have a particularly high specific energy compared to newer battery types. I'm sure you've seen videos of LiPo batteries experiencing thermal runaway where they actually explode and / or go up in flames, with probably the most well-known case being the Boeing 787 (and that was a specially armored and protected aviation model). That's one of the reasons that UPS systems don't use them but stick with traditional VRLA batteries.
Lead Acid Battery Thermal Runaway
Share
Replies 2
Share
This reply was originally posted by Angela on APC forums on 8/20/2015
Hi Damien,
I can't find a specific user's guide for this UPS but the model that replaced it, SURT2000XLI would shutdown and give you a front panel indicator/LED pattern showing it shutdown from overtemp and then turn off while continuing to show the LED pattern. I do not believe there would be an audible alarm but I can't say for certain. I tell you this because my educated guess is that the model you have would act the same way or very similar.
Share
Terry_Kennedy_apc
Share
Share
Additional options
Already have an account?Login
