APC Smart 1000VA(700W) crashed
  • APC Smart 1000VA(700W) crashed
145
Posted: ‎2021-06-29 05:37 AM . Last Modified: ‎2024-03-13 12:47 AM
3181
Helloto all.yesterdaywhile I hadthe UPSon anda load of about100Wat one pointandjumped in witha bigbang, making me jumpa10Abreakerbefore theUPS.
Idisassembledit and founda diode(D21) witha while yousmoke.thestrange thing is thatnotskippedthe diodebutas if wehadputa wire betweenthe pins.
canan insect orspider thatwas wanderinginside?
here are the pictures:
http://s5.postimg.org/rktpuaul3/IMG_2844.jpg
http://s2.postimg.org/3lfoi8oq1/Foto_10_04_13_06_05_26.jpg
on the motherboardtherewrote:LYNX2kVAMAIN BOARD
the model of theUPSis previousto the onethat is marketedtoday
ie: SUOL1000XLI
instead of the current:SURT1000XLI
wherethereis little differencein components.
SUOL1000XLI
http://s5.postimg.org/6g47e0wuv/646.jpg
SURT1000XLI
http://article.tech-labs.ru/img/article/7554/DSC07683.jpg
Posted: ‎2021-06-29 05:38 AM . Last Modified: ‎2024-03-13 12:47 AM
lightsso.all the othersare off.
but therea legendwiththeerror description?
Replies 13
Can you confirm what LEDs and if you're reading top to bottom or bottom to top?
above is how i look at the battery bar graph. Can you change the ones you see on to "1?"
There is but it is not public consumption smile
Also, this indicates a fan fault.
I would like tounderstand whythismight have happened.
andbecause it is nota fusewirewas placedat the inlet.Fortunatelydebreaker thatI had installed10AretrospectIcould seesmokeor fireworkswould jumpfincethemain25A.
Iusethe UPSaswell as inlive audiotosendthe audio mixeranddevicessensitive tovoltagefluctuationsorcalamenti.
ifwhathappened to meinthe geneduring the eveningI wasbadlyput.
at the timethe defectwas in the houseand I hadtheupsas wellinexternal bypassrelay. thatthe fall of theupsutilitieswerepoweredfrom the mains.
with this thingandnowI have littleconfidenceto taketheupsinaudioserivce.
anditmaywellhave beentheupsa littleolder andnotdouble-checkedby you.
I am wondering if someone with this UPS can give me the specifications of the red metal film capacity in the top right hand corner of the board (see attached photo)? I have a damaged unit with that capacitor broken off and want to repair it.
Also what is the difference between the units that have two 4,000uF caps (the big blue ones on the right) vs. the ones that only have 1?
Barry
ie: SUOL1000XLI
SUOL1000XLI
SURT1000XLI
Wasnt an insect, components fail over time, Whats the model / Serial no of the unit?
In fact,Ihavethis thingI noteas well. Apparently therehas beena dischargeto the radiator.
  hereby replacedthe diode, I will burnthesameFuses1ampere.
The UPSandthe old model1000seriessmartSUOL1000XL
withserial number: YSD3D4110613
I wantso much to thisups, has a perfect sine waveform. imppecabileidireihere isa demonstration madeby me:
APC Smart UPS 1000VA sine wave comparating line vs. ups output - YouTube
withanexternalrelaybypass: LINE<->UPS
That model number isn't correct the serial number doesn't seem right either tongue-out
my mistake
YS0304110613
Posted: ‎2021-06-29 05:38 AM . Last Modified: ‎2024-03-13 12:46 AM
Hi Mihai,
Can you please send me a close up of the resister burned in my UPS motherboard.Picture is attached. I tried to identify the resister from your pictures,but its not clear when i enlarge it.
Thank you
Please, somebody has the data sheet, APC LYNX 1Kva control board????
On 4/30/2014 8:36 AM, Barry said:
Barry
10mF x 100VDC
