AP9631 Network Interface restarted
  • AP9631 Network Interface restarted
Posted: ‎2021-06-29 06:15 AM . Last Modified: ‎2024-03-12 11:50 PM
6036
I have an AP9631 that seems to "Network Interface restarted" every couple days or so.  I have upgraded the firmware to v.6.4.6 , but this has not solved the issue. I looked through the logs files but dont see anything helps narrow down where the problem is.
I am attaching the sanitized files if anyone could help narrow down the issue.
  • ap9631
  • resetting
Philipp_apc
Ensign Philipp_apc
Ensign
Posted: ‎2021-06-29 06:15 AM . Last Modified: ‎2024-03-12 11:49 PM
@APC I could reproduce the behavior again and got a core dump where should I send the snapshot?
Snippets:
dump.txt
09/07/2018 10:17:26 Failsafe Reset
Specific code = 200
AOS v6.5.6 rpdu2 v6.5.6
Serial Number: 5A1750E04651
AOS Binary Date/Time: Mar 30 2018 16:51:08
APP Binary Date/Time: Apr 24 2018 11:42:41
Task Dump Task ID 166
 Data in RAM is incomplete - dump aborted!
events.txt:
09/12/2018    21:53:37    System    Network Interface restarted.    0x0002 (occurs multiple times)
debug.txt:
09/12/2018 21:20:27 Requested Reset
09/12/2018 21:53:38 Failsafe Reset
09/12/2018 22:49:52 Failsafe Reset
09/07/2018 09:18:33 .\os\os_heap.c:191 check_heap: block size mismatch. 09/07/2018 09:18:40 Software Exception Reset
09/07/2018 10:14:21
Less than 100 bytes in stack, task 220
Replies 5
There's a watchdog timer built into the AP9631 platform. If the network is quiet enough, it might sense the lack of traffic as a problem and restart the management card. There is also a ping test that takes place from time to time and a failure there could also restart the card.
Janeway
It looks like a known issue with that firmware -- you could try reducing notifications ie removing SNMP trap receivers and email recipients.
Philipp_apc
Ensign Philipp_apc
Ensign
Will there be a possibility to disable this watchdog and/or ping feature in the future?
I tried to disable all unecessary services: ftp, snmp but I still get the network card restart and it takes up to 4 minutes
It is especially annoying for me because I use the APC7920B in automated tests which then fail because I cannot connect to the device when the interface is restarting.
Additional information:
aos: v6.5.6
rpdu2g: v6.5.6
bootmon: v1.0.8
Terry_Kennedy_apc
Commander Terry_Kennedy_apc
Commander
If you request a "Technical Support Debug Information Download" from the About / Support web page on your device, you'll get a .tar.gz file which contains a number of useful things. I don't remember which file it is (maybe the debug one), but one of them has a code identifying the cause of the watchdog reset. One of the APC folks can probably look that up for you and tell you why your card is resetting.
Philipp_apc
Ensign Philipp_apc
Ensign
Snippets:
dump.txt
Specific code = 200
events.txt:
debug.txt:
09/07/2018 10:14:21
