  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
AP9619, AP9618, AP9617 Firmware Question
  • Communities
  • Re: AP9619, AP9618, AP9617 Firmware Question
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
ryan.schwellenbach_apc
Ensign ryan.schwellenbach_apc
Posted: ‎2021-07-08 12:46 AM
1586
This was originally posted on APC forums on 6/23/2015
We would like to bring all of our GEN1 NICs up to date on firmware and have a few questions:
  1. What is the most recent version? Also, are the cards AP9619, AP9618, AP9617 all compatible with the same firmware versions?
  2. Is there a utility that can be used to push the firmware to a large number of devices, similar to the GEN2 utility used to upgrae to AP9631 cards to v6.2.0?
  3. Are there any known issues when upgrading the firmware on GEN1 cards? We will be upgrading remotely and would not have physical access to a card if it failed.
Thanks!
Ryan
  • ap9617
  • ap9618
  • ap9619
  • firmware
This reply was originally posted by Angela on APC forums on 6/23/2015
Hi Ryan,
1.) It depends on the UPS/device it goes in. Let's assume Smart-UPS - it would be AOS 3.7.3/sumx application v3.7.2. Look for part number SFSUMX372 on the firmware download page. AP9617/18/19 would always use the same firmware. I can't think of a time that they wouldn't when used in a UPS.
2.) Yes, detail on doing that with NMC1 devices is outlined here -> http://www.apc.com/support/index?page=content&country=ITB〈=en&locale=en_US&id=FA156099 You use iplist.txt very similarly to the NMC2 devices. You download the SFSUMX372 and the wizard/utility is available in that .exe you extract the files from.
3.) What version do you have on there now? There are no known issues beyond if you are on firmware v1.X, and want to go to the latest, you need to put AOS 2.0.2 on, then continue with the newest AOS and application. Other than that, sometimes the wizard utility may fail if your NMC takes too long to boot up and continue loading the second file or if you have a really slow network connection. I'd personally recommend you only do groups of 5-10 cards at a time to keep an eye on things if you won't have physical access. Some of the network issues may be unpredictable so if you won't have physical access, small groups would be good. Most of the time, you can still get to the device remotely and would just have to re-run the wizard or manually FTP the upgrade which can be done remotely still.
Let us know if you have any other questions. Hope that helps.
Replies 2
Hi Ryan,
This was originally posted on APC forums on 6/25/2015
Angela,
All of our GEN1 cards are v3.1.3 and above. I will download the firmware upgrade utility and try a few at a time. Thanks for your help!
Additional options
