Get the latest news, release notes, and other need-to-know information about EcoStruxure IT Advisor
EcoStruxure IT Support
December 2025
Desktop client
A new desktop client is not required for this release. Use the ITA 9.5.0 desktop client.
This release includes:
In the Network context, a new Network connection wizard allows you to create, edit, delete network connections between assets in racks, in rooms, and between patch panels.
In the Power context, you can now set or modify breaker panel settings and connection information including the panel name, panel derating, and the assigned breaker and power consumer.
Available to customers using the Cooling Optimize integration with IT Advisor
Influence maps are now available in the Power context at the rack and cooling unit levels.
Two new reports are available in the ITA Reports view:
- Cooling Optimize Benchmark
- Temperature Compliance
Note: Customers can add the Cooling Optimize integration on the Administration > External System Configurations page in the ITA web client.
The IT Advisor web client now supports three light mode themes: Light, Dark, and Device.
Device mode matches the operating system preference.
Click the icon in the menu to toggle between light modes.
You can now create query groups and save queries into groups in the equipment browser.
Set the query name, define filters, add or choose an existing query name, and save your query.
Use the Saved Queries floor view overlay in the floor view to view matching assets from saved queries.
Available in the web client only
You can now divide racks into logical sections called compartments and add rack mountable assets to them. You can assign customers to compartments, especially beneficial for colocations.
Compartments are defined by new genomes. Before you can add compartments to a rack, you must assign the compartment genomes to your local genomes.
Search for Compartment on the Genomes > Genome Library page, select, and then click Add to My Genomes.
The default compartment sizes are 1U, 2U, and 4U. You can copy and edit them in the My Genomes view.
July 2025
Tiers are defined as a layer or area of space designated at a specific height from the ceiling or floor of a room. For example, a tier can be defined as a 10 inch tall space that starts 18 inches below the ceiling.
You define tiers from room or location properties. When defined for a location, all rooms in that location inherit those tiers.
Tiers can contain one or more busbars or cable trays, or both.
Tiers can be color coded. Objects assigned to the tier, such as bus bars or cable trays, inherit the tier color.
Note: Infrastructure Tiers are called Room Layers in the ITA desktop client. The ITA desktop client will continue to use the term Room Layers for now.
Bus bar management is a new IT Advisor web client feature.
Bus bars are defined as room fixtures like rows and containment systems and must be assigned to an infrastructure tier.
Bus bar features in the desktop client are limited:
Power connections to bus bar tap down boxes can be managed in both the web client and the desktop client.
Cable tray sections and drop tray sections can now be created in both the IT Advisor web and the desktop client.
Creating and managing network connections is currently limited to the desktop client. The web client will include these features in a future release.
A Cooling overlay was added to the IT Advisor web client. This overlay is identical to the cooling overlay in the desktop client.
View cooling information and settings on the Cooling tab in the attributes view.
The Dashboard editor was improved to include:
There are no new known issues in this release.
| IMPORTANT: All existing dashboards from ITA 9.5.0 and earlier were removed and must be recreated. |
Dashboards are created per user.
Dashboard widgets are currently limited to IT Advisor related information.
Dashboard widgets may need Capacity license installed.
You can change, move, and resize widget positions.
Sustainability dashboard from a template
Users, User Groups, and Customers pages in the Administration menu were updated to align with other Schneider Electric software products.
Users
Add new user button; Search field
User groups
Create new user group button; Search field, indicator for number of group members
Customers
Add new customer button; Search field
Each context has its own toolbar on the left.
Note: The Network context is read-only at this time. Improvements coming in a future release.
Explorer view includes device alarm information (requires Data Center Expert integration).
Select a rack to edit content in Pinned view.
Example: Floor view Asset editor
Rack shading on the floor view is based on capacity settings; red is critical, yellow is warning.
Capacity Licensing enables rack/device overlays that display capacity information based on the selected context.
Add assets in rack view
You can now add, change, and delete assets and edit properties in rack view.
Power connection properties
U position is now included in in the rack properties.
Click the toggle at the bottom of the floor view to see the Power Dependency tab which provides access to the power path layout.
Device association
Associate a device from an external system (Data Center Expert or IT Expert) to an IT Advisor asset.
Click the arrow > for the device to see its Properties, Product and Matches panes.
Configure and manage integrations with Data Center Expert and IT Expert servers on the Configuration > External systems page in the web client.
Note: Only one IT Expert connection is allowed at a time.
You can now change the title and logo in reports.
If the Name field is empty, the default name is used. The custom report name is not saved permanantly.
You can upload two different image files for a logo. The selected file is used.
If no logo is selected, the default Schneider Electric logo is used. The selected logo is not saved permanantly.
A Request new genome button on the Genomes > Genome Library and My Genomes pages now opens a web page to a request form at https://app.ecostruxureit.com/request/.
Internet access is required.
Single sign on from EcoStruxure IT Expert now works as expected.
ETL measurements are now sorted properly after import.
You can now assign customers to new or open cages and racks as expected.
Cable trays can now be configured on a plain floor.
A cold aisle containment system (CACS) can be added to the desktop client and the web client as expected.
The test patch API operation executes as expected.
The multiple asset patch APi operation no longer sets the same barcode on linked equipment.
Unable to move doors and windows from the ITA web UI
When the PUE dashboard is created based on the template, no data appears in the dashboard.
Some customers are experiencing long delays when opening or closing rooms in the equipment browser pane. This issue is more noticeable in large models.
A new desktop is required for the IT Advisor 9.5.0 release.
You can now generate reports in the web client.
Click Reports and select a report type. Select a date range, location, and the information to include and click Generate Report.
Click Export Report to save as a PDF.
Available reports include:
- Model: Contains Inventory and Genomes
- Analyze: Contains Dashboard and Reports
- Manage: Contains Change Management
