Showing Alarms for Selected Equipment Only
Viewing alarms from external systems
Send InviteCancel
You can filter the contents of the Alarms pane to display only alarms related to the selection (locations, rooms, equipment, or devices) in the layout (floor, rack, or list) or Navigation pane.
Click the Link view with selected equipment icon to enable this feature. 102237337_360037995414.png
Select equipment in the Layout or Navigation pane that you want to see in the Alarms pane.
Click the link icon again to disable this feature. 102237234_360037995414.png
