ATV630 and ATV930 Process drives
  • Industrial Automation
  • Solutions for Motor Management
  • ATV630 and ATV930 Process drives
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Zika-Richard11
Ensign Zika-Richard11
Ensign
Posted: ‎2024-11-19 12:17 PM
1905
What can cause an INF8 or Internal 8 error on the ATV630 and ATV930 Process drives?
  • Low Voltage AC Drives
Lauryn_Cossard
Lt. Commander Lauryn_Cossard Lt. Commander
Lt. Commander
Posted: ‎2024-11-20 12:25 AM
The probable cause of this error is that the internal 24vdc power supply is not correct or the 13v, 5v or 24vdc control voltage is not ok.
To solve it :
- Check with SoMove which power supply
- Change main control board of the drive.
- Change power board
BJacqz
Commander
Posted: ‎2024-11-20 12:58 AM
Please have a look inside our programming manual, this is a first approach to possible cause and remedy. In this case, I would advise you to contact your local technical support .
Bruno Jacqz, Drives training leader
SESA153041
Crewman SESA153041 Crewman
Crewman
Posted: ‎2024-11-23 05:08 AM
Apart from the recommendations above and the possible root causes and remedies mentioned in the programming manual, also try to remove all external control wiring first and reboot the drive to check if the INF8 dissapears or not. We have had a field experience where the INF8 was caused by a short circuit inside the remote door mounting kit (VW3A1112) connected via an ethernet cable with the HMI port of the drive => INF8 caused by an external device to the drive
Lauryn_Cossard
Lt. Commander
To solve it :
BJacqz
Commander
SESA153041
Crewman
