I cannot find any limits in the documantation for:
Since the default response size is 200, is it ok if we pass this parameter value as a big (e.g., max value of integer) number, to get all items? Otherwise, what is the upper limit?
At the same time, creating subscription endpoint should also be able to accept big number of ids. So, another question here is, can we provide 10-20k (or 2147483647 😊) ids for a single subscription?
BR,
Erwin
Hey Erwin!
I am not sure there are any limit on this.
The actual limit being the capability of the machine that run on.
If the machine is powerful enough, maybe you can get !M notification at a time.
I think the same goes with your second question.
I will still ask R&D about that to be sure.
Max
Hey Erwin!
Max
