Send InviteCancel
2022-11-0703:10 AM
API request limitations
I cannot find any limits in the documantation for:
Since the default response size is 200, is it ok if we pass this parameter value as a big (e.g., max value of integer) number, to get all items? Otherwise, what is the upper limit?
At the same time, creating subscription endpoint should also be able to accept big number of ids. So, another question here is, can we provide 10-20k (or 2147483647 😊) ids for a single subscription?
