Atv320U30N4B Inverter
  • Atv320U30N4B Inverter
David_SE
Captain David_SE Captain
143
Alfred_SE
24
Maude.wiser.
22
Eng-Zeru
Eng-Zeru
Cadet
Posted: ‎2024-04-14 09:10 PM
736
Frequency fluctuation of @ATV3tb20U3tb0N4B – If I set above 10Hz set point – output frequeny is okay from drive and if I set 3-10Hz, it give fluctuation in drive output frequency and it varies from setpoint value to maximum set frequency. I has also been noted that high sound at the motor. The drive application marble block cutter machine. Please advise Solution
  • Energy management
PCDTC
Crewman PCDTC
Crewman
Posted: ‎2024-04-24 08:30 AM
The load is high on the motor so at low speed you cannot get same torque, either keep higher speed or try to boost torque in the vfd .
PCDTC
Crewman PCDTC
Crewman
