Serck eNet module E2769
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Serck eNet module E2769
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
nicolasdelannoy
Crewman nicolasdelannoy Crewman
Crewman
Posted: ‎2024-12-16 05:26 AM
2040
Hello all,
We are looking for any technical documentation / user manual on an old module ref SERCK CONTROLS eNet E2769,
Is there someone could provide information?
  • RTU
  • Telemetry
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Joel_Weder
Captain
Posted: ‎2024-12-18 08:58 AM
2010
Hello Nicolas,
The Serck eNET RTUs were the 386 and 586, according to one of our long-time experts. The 586 was re-named as SCADAPack ES at one point. There was also a rack-mountable version called the ER. But our expert was not able to identify "E2769". He thought perhaps this is a serial number rather than a model ? A photo of the device might be helpful for identification.
Are you able to connect to the RTU at all? If so, it would be helpful to know the firmware version. For now, I've attached the manual for a 386 eNET model RTU. Let us know if this is similar to the device you're working on.
I've also attached a datasheet for a newer SCADAPack ES, after re-branding with the Control Microsystems name. One difference between the 386 and 586 models apparently is that the 586 includes two LAN ports.
Joel Weder
Remote Operations Specialist
Joel_Weder
Captain
Posted: ‎2024-12-20 07:45 AM . Last Modified: ‎2024-12-20 07:53 AM
In response to nicolasdelannoy
That certainly looks like a 386 type RTU. Looks identical to the photo on page 12 of the manual. Have you taken a look at the user manual I shared? It should help...
Joel Weder
Joel_Weder
Captain
2011
Hello Nicolas,
Joel Weder
nicolasdelannoy
Crewman
Posted: ‎2024-12-19 05:14 AM
In response to Joel_Weder
1994
Hello Joel,
Thank you for your answer,
find attached a photo of the module.
Joel_Weder
Captain
Joel Weder
