SCADAPack 474 max IOs
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • SCADAPack 474 max IOs
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Posted: ‎2021-07-13 08:59 PM
1
2332
Dear Team,
I would like to know with Latest 474 controller how many Maximum 5606 IO Expansion module i can use.
  • RTU
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Joel_Weder
Captain
Posted: ‎2021-07-14 08:53 AM . Last Modified: ‎2021-07-14 09:08 AM
Hello Sameer,
The SCADAPack 47x datasheet (copy attached) lists the maximum number of expansion modules at 15. This is in the "Additional I/O" section near the bottom of page 6. Also, see note 7 at the bottom of the page about the possible requirement for additional power supplies.
A solid-state 5606 requires 400 mA, which at 5 volts on the bus is 2 watts. A relay version requires 600 mA, which is 3 watts. The 474's internal power supply could power one of the relay modules, or two of the solid-state type. Beyond that, external power supply would be required. The model 5103 power supply can provide 5 Vdc to the bus at 2 amps, or 10 watts total. So you'd need several 5103's to power 15 x 5606's.
Our new 6103 power supply, due to be released this month, has the same output capacity, but one additional benefit. It includes a 16-pin output bus connector for 5000 series modules, so there is no need to add a 20-to-16-pin adapter.
Joel Weder
Remote Operations Specialist
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Joel_Weder
Captain
Hello Sameer,
Joel Weder
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
