File Export with Function Block Diagram to Network Location
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • File Export with Function Block Diagram to Network Location
Joel_Weder
Captain Joel_Weder Captain
91
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
MartinChartrand
Captain MartinChartrand Captain
15
dw_fbemc
Crewman dw_fbemc
Crewman
Posted: ‎2021-07-15 12:22 PM
948
I am trying to create a simple CSV file with a function block diagram to be created every 5 minutes and written to a network drive.  Everything works fine when the program writes the file to the local C drive but when I point it to the network drive, it does not write the file there and I don't see any errors or indications of why it is not writing it.  Does anyone have any suggestions on how to troubleshoot this?  I can copy and paste files from windows file explorer to this same location so I think permissions are set to allow writing but for some reason it will not write the file to this network location.  Let me know if additional details or information would help you to understand the problem better.
Thanks!
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2021-07-16 01:50 AM . Last Modified: ‎2022-10-19 01:34 AM
You've not specified which product you are using, but I'm guessing its Geo SCADA Export (formally ClearSCADA).
Geo SCADA Expert has its own forum (this forum is for SCADAPack devices):
https://community.se.com/t5/Geo-SCADA-Expert-Forum/bd-p/ecostruxure-geo-scada-expert-forum
The Geo SCADA Expert server is running as a Windows service under the built-in SYSTEM user account. This user account doesn't have access to any network resources, so you can't access network drives from a Windows service.
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
