[Imported] RealFLO Register Overlap
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] RealFLO Register Overlap
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Flow Measurements
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-10-25 02:45 PM
>>Message imported from previous forum - Category:Realflo Electronic Flow Measurement<<
User: mchartrand, originally posted: 2018-10-17 19:05:18 Id:89
**_Berkelium:
Reading the RealFLO 6 TeleBUS protocol reference manual, it would appear that there is a register overlap between the AGA-7 configuration structures and the V-Cone Point 4 Reynold's Number and CoEfficient config. and actual registers.
Is the manual correct? If so, are there any other known registers that overlap in RealFLO?_**
__________________________________
mchartrand:
I believe that because V-Cone or AGA-7 cannot be configured at the same time, i.e. the flow computer can only do one type of flow calculation per flow run, that there may be some overlap of registers in certain places. We had to make use of a limited number of Modbus registers so there are certain blocks of them that do double duty.
  • RTU
Replies 0
