Easergy Builder - In CoreDB, how to configure Modbus slave device's SPC command into bits (.i.e., HR 1 having bit 6 for SPC command)?
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Easergy Builder - In CoreDB, how to configure Modbus slave device's SPC command into bits (.i.e., HR 1 having bit 6 for SPC c...
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
Rajeev_211
Crewman Rajeev_211 Crewman
Crewman
Posted: ‎2025-07-08 07:33 PM . Last Modified: ‎2025-07-09 12:32 AM
607
I have to add a modbus slave device SPC (single point command) command having register address 1 (holding) HR bit 6 in Saitel HUe easergy builder configuration, how to map in coredb?
I tried mapping but during compilation, errors are there for the mapped points.
I have attached the screenshot for the configuration.
Kindly help me in correcting it.
  • PowerLogic T300
  • PowerLogic T500
Tags (7)
  • Easergy Builder
  • PowerLogic T300
  • PowerLogic T500
  • Saitel
  • t300
  • T500
Replies 5
JuanRayo
Lt. Commander JuanRayo Lt. Commander
Lt. Commander
Posted: ‎2025-07-08 11:35 PM
Hello Rajeev.
Please share here the Easergy Builder configuration and let me know the name of the slave bin controller
Rajeev_211
Crewman
Posted: ‎2025-07-09 12:05 AM
I have shared you the configuration files, pls check
JuanRayo
Lt. Commander
Posted: ‎2025-07-09 04:58 AM
Hello Rajeev.
If I understood well you need to write  a Single Point Command in the bit 6 of a Holding Register.
For this you can use "status" and its mask as in the pictures you attached but here I am adding another way to write down a "true" in the bit 6 of a Holding Register.
Basically "COMMAND1 or 2" are the booleans you handle to send the command to the modbus slave device.
Rajeev_211
Crewman
Posted: ‎2025-07-09 06:23 PM
ok. Thank you so much for this help and support, can you please share the DB you have modified.
JuanRayo
Lt. Commander
Posted: ‎2025-07-10 02:09 AM
Hello Rajeev.
I am attaching the modified DB. Basically I have added a new 104slave bin controller as an example just to give some sense to the previous post.
unzip it and import it from Easergy Builder.
Lily2.tar.gz.zip
