Dear Experts,
We will integration RTU and P3U30 using IEC-61850. Finally All data metering and status appear normally in RTU. The Problem is when we try to command DO (object1) didn't work with notification 'Access-Violation' using IED Scout. I have make sure that relay ready in remote mode.
Would you give us some advice with this issue?
Thank You and Regards
Rizal
Hi @Juha ,
Thank you very much your advices, I have make sure all as your suggest but still not working. Finally i got the solution, I tried to downgrade the version of esetup easergy pro to version 3.8.0 and it's working normally.
Regards
Rizal
Hi Ms,
Please try to change "Originator Category" to "station-control". I usually use that one to give Scout a command.
Hope this is useful.
I'm glad to receive your feedback about this solution, or if you fixed it differently.
Hi @rizalul_arifin , thanks for you question.
There can be several different reason for this access violation message, like the following:
- control is performed to the same position as present one (open to open or close to close)
- operation is blocked in the relay (by the use of object blocking matrix)
- even if relay is in remote state local/remote event is blocked and then status in the server is local
- control command type is not in line with current control model (one step vs 2 step command)
BR
-juha-
Hi @Juha ,
Regards
Rizal
