This forum is created for the exchange of information and open dialogue regarding electrical power monitoring and energy automation products and services. Participants will have access to downloadable material as well as chat opportunities with subject matter experts.
Posted: 2023-03-10 06:23 AM
hello,
Did anyone encountered this scenario or similar scenario?
how can I add T300 to the PME?
Do I need driver for T300 and shark100 in order to integrate it to PME?
Posted: 2023-03-10 06:49 AM
Hello @benjoe_herrera ,
You can use the Device Type Editor to add the T300 as a Modbus device. The same can be done for the Shark 100 using Modbus protocol.
The Device Type Editor can be found in Management Console under Tools>System>Device Type Editor. You can select quantities from the measurement tree and map them to the Modbus points from the Modbus RTU device.
I've not built device types for the Shark, but there may be someone on the forum that already has.
Posted: 2023-03-10 03:10 PM
Thank you @N4th4n13L
Hoping someone has device types for the shark100.
How about adding T300 on the device type editor, do we have modbus registry for T300? I dont have any idea on how to do it.
Posted: 2023-03-12 11:07 PM
i got error on device type installer while doing 3rd party device.
the error is “ Cannot find ProductRegInfo. Is DTI installed correctly?”
I saw this https://www.se.com/ww/en/faqs/FA364751/
but I already log in administrator. But still the error occurs.
anyone can help me to find solution? Or anyone experience the same
Posted: 2023-03-16 08:44 AM
Hi!
The process has been described properly in the posts above. T300 is not natively supported by PME, so it requires a driver creation in Device Type Editor. For that you need to know the Modbus map of your device. This also means it will require a Mid-range device license per T300.
PME System Guide includes guidelines on how to use the DTE tool. If errors are experienced during the process - I recommend to reach out to tech support for troubleshooting.
Regards
