Hi to all!
I have problem with Partial energy reset on a iEM3165 meter.
From the manual i read that is simply necessary write 2020 on the AnalogValue command.
I did, but the energy is not resetting.
As the screenshot attached you can see the AnalogValue is correctly writed, but the Partial Energy is the same.
I use Niagara Workbench as client and the Meter is connected to an Honeywell Controller.
Hi to all!
I figured out that the problem is on Controller side.
I make a mistake writing the Bacnet point with different version between Workbench and Controller OS.
Now is possible to close the case
