Looking for the right place to send hardware questions...... Is this IT?
Post questions from the target area rather than start a post from the top level and find a location. It will be much easier to do. Power Metering is down one layer from Monitoring Hardware as Insulation Monitors and ION Setup are also part of Monitoring Hardware.
Assuming by your tag that you mean power metering. I have moved it to that area for you. Please let me know if that is not the correct area.
That is not where I put it?
.Here is what I see for places.... Picked the one that looked best
Its OK, I love the assist. Just getting use to the spaces.
Michael
Is there a short-cut to find target area? The hierarchy has us start high and drill down. Do not want to put too fine of a point and have it miss.
If you see the area that has the "Ask Questions, Find Solutions, Share Knowledge" etc then you are at a level where you should post. Most higher level areas are navigation areas only so we remove the ask a question button from the page. The path you followed can allow it though, however nobody will be monitoring it if it is not at the product level community (PME, PSE, Power Metering, etc). Hope that helps.
