Two IP addresses on AS-P
Metering & Power Quality
Send InviteCancel
2023-10-2609:43 PM
Is it possible to have two IP addresses from different subnets on one AS-P device?
There are two ethernet ports, each one with its own mac address.
One port is currently used for PME data exchange (static IP address), and we plan to use other port for to connect to the LAN (using DHCP).
We will make use of a Dual IP setup.
We have tested this scenario, and it doesn't seem to work. Just wanted to confirm if this is possible and if anybody else maybe managed to get it to work.
Apologies in advance if this has been posted in the wrong section.
