Two IP addresses on AS-P
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Re: Two IP addresses on AS-P
Charles_Murison
Charles_Murison Champion
571
Mehran_Mehrnia
Mehran_Mehrnia Champion
203
Ramasamy_N
Ramasamy_N Champion
115
Gummy_Bear
Gummy_Bear
Explorer
Posted: ‎2023-10-26 09:43 PM
2083
Is it possible to have two IP addresses from different subnets on one AS-P device?
There are two ethernet ports, each one with its own mac address.
One port is currently used for PME data exchange (static IP address), and we plan to use other port for to connect to the LAN (using DHCP).
We will make use of a Dual IP setup.
We have tested this scenario, and it doesn't seem to work. Just wanted to confirm if this is possible and if anybody else maybe managed to get it to work.
Apologies in advance if this has been posted in the wrong section.
  • PowerTag Energy
  • AS-P DUAL IP
Romain_Polette
Romain_Polette Champion
Champion
Posted: ‎2025-02-11 11:39 PM
Hi @Gummy_Bear and @MCole ,
Building community here:
https://community.se.com/t5/EcoStruxure-Building/ct-p/building-management
Only topics related to Power Meters are discussed here.
Romain POLETTE
Solution Architect - France Operations
Reply 1
Romain_Polette
Champion
Romain POLETTE
