Is it possible to have two IP addresses from different subnets on one Ion9000 device?
There are two ethernet ports, two MACs.
One port is currently used for PME data exchange, and we plan to use other port for IEC61850 in separate RTU subnet.
Thanks.
Hello @Oz_Ba ,
No, currently the ION9000 meter only has a single IP address for both ports.
Charles
Hello @danielbarrantes ,
Correct, ION7400 and PM8000 also only have a single IP address for both ports.
Charles
Also the two TCP ports are presently available only for bridging to another device (and not for two separate networks). So even if you had two networks which would allow for an ION meter to use an IP address for both networks, the two networks would not be isolated from one another.
