Replacement of BCPM parts
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Replacement of BCPM parts
Charles_Murison
Picard Charles_Murison Picard
504
Ramasamy_N
Captain Ramasamy_N Captain
115
Mehran_Mehrnia
Captain Mehran_Mehrnia Captain
109
Robert_Lee
Admiral Robert_Lee Admiral
96
Miyai
Lieutenant Miyai
Lieutenant
Posted: ‎2023-10-31 05:45 PM
1
798
Unable to measure current in one circuit with BCPMA084S.
We believe that one CT unit has failed.
If this is the case, to what extent should parts be replaced?
Replace only the CT board? Or replace the entire CT board and the complete CPU board?
Miyai
  • Did you know
Charles_Murison
Posted: ‎2025-01-10 04:23 PM
Loaded question has may depend on the hardware version of the product. Some versions the CT strips were calibrated with the board, other versions the CT trips and CPU boards were calibrated separately.
Recommend reaching out to your local technical support with product details including Serial number.
Charles
Charles_Murison
Charles
