Continue
  • My Subscriptions
  • Events
Recover password of power meter PM710
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Recover password of power meter PM710
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
sesa294402
sesa294402 Leader
Leader
Posted: ‎2014-11-06 02:08 AM
2733
Hi all,
We have a customer is using our power meters PM710 (firmware version 2.0 - 3.0). The contractor had installed wrong CT ratio so that we need to support them. The problem here that they had changed the password (default password is 0000).
So please support to let us know how to recover password (update firmware or we have master password).
Thanks so much your support.
Tags (2)
  • meter
  • power
dborle
dborle Leader
Leader
Posted: ‎2014-11-06 04:17 AM
Hi Tran Bao,
No, unfortunately it seems that backdoor passwords for PM700 with versions that are less than V3.04 are not supported. But try to contact the technical support, maybe they can provide you another solution.
  • Hi
dborle
dborle Leader
Leader
Posted: ‎2014-11-06 02:22 AM
2677
Hi Tran Bao,
If firmware is V3.040 or higher, then I can provide you a backdoor password. For this I need the serial number of the related PM.
Regards
Daniel
sesa294402
sesa294402 Leader
Leader
Posted: ‎2014-11-06 02:59 AM
2678
Hi Daniel,
They have around 40 PM710. They have both firmware v.2.02 and 3.04. Do you have any solution with v.2.02?
dborle
dborle Leader
Leader
Hi Tran Bao,
  • Hi
