Continue
  • My Subscriptions
  • Events
Power Analyzer ION 8000
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Power Analyzer ION 8000
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Imran_Malik739
Imran_Malik739
Explorer
Posted: ‎2025-01-23 12:53 AM
1454
Please find an analyzer which is IEC 61850 (PRP) compliant + capable for recording power abnormalities (Power Dips)/Voltage fluctuation less then the sampling rate of 100ms* .
  • iEM3000
  • ION8000
Mehran_Mehrnia
Champion
Posted: ‎2025-01-23 04:52 PM
Hi @Imran_Malik739
ION meters, such as the PM8000, support four IEC 61850 connections and have two separate Ethernet ports, but only one single IP address is supported for both physical Ethernet connections.
Parallel Redundancy Protocol(PRP) needs two different Ethernet networks which is not supported by the meter.
ION meters support logging of PQ incidents less than 100 ms.
Best Regards,
-Mehran
L3 Expert Advanced metering
Mehran_Mehrnia
Champion
Hi @Imran_Malik739
Best Regards,
-Mehran
Imran_Malik739
Imran_Malik739
Explorer
Posted: ‎2025-01-23 07:50 PM
  • Thank for you your valued response. Kindly advise if you would recommend any model number that would fit in for our purpose.
Mehran_Mehrnia
Champion
Posted: ‎2025-01-24 10:58 AM
Hi @Imran_Malik739
You're welcome.
Based on my knowledge, none of the ION and Power Logic meters support PRP. The only redundancy topology we support is RSTP which uses a single network.
I recommend contacting your local sales team for more information.
Best Regards,
-Mehran
