Continue
  • My Subscriptions
  • Events
PME and OPC Server (third Party - Kepware)
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PME and OPC Server (third Party - Kepware)
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
SD23
SD23
Explorer
Posted: ‎2024-03-27 11:25 AM
2125
Hello, I am trying to connect to OPC server Kepware. I get an error immediately (OPC Translator: failed to connect) in the management console log when I add a new OPC site. I have used the address as follow: opcda://localhost/Kepware.KEPServerEX.V6
Knowing the OPC quick client is connecting to server Kepware.KEPServerEX.V6. Is the problem in PME or the OPC server?
I am using PME 2023.
Tags (5)
  • dte
  • opc
  • PME2023
  • thirdparty
Rafaela_Cordeiro
Rafaela_Cordeiro Leader
Leader
Posted: ‎2024-04-01 11:19 AM
I recommend you opening a case with your local and provide a full system diagnostics to them.
You can contact your local support thru this link: https://www.se.com/ww/en/work/support/country-selector/contact-us.jsp
FAQ on how to retrieve system diagnostics: https://www.se.com/us/en/faqs/FA275753/
Rafaela_Cordeiro
Leader
