Continue
  • My Subscriptions
  • Events
PM8000 issue downloading
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM8000 issue downloading
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
BrianW
BrianW
Contributor
Posted: ‎2024-03-07 04:57 AM
1863
Hi all,
I have an urgent question for the board.
We are testing a PDU for a FAT and noticed that when the supply is first connected to the single PM8000 remote display unit, the display powers up and after the Schneider Electric screen, it shows that it its trying to "download" possibly firmware?
I connected to the PM8000 over IP and tried using EcoStruxure Power Commission to see if I could upgrade the firmware. While EPC finds the meter over IP, and I click on show firmware, it keeps coming back as Can't find device. I tried doing a Master Rest using the meter web server. and the display seems to work but extremely sluggish then freezes.
I have not seen the meter ever attempting a download before. The model type is METSEPM8243. Also showing on the Schneider Electric screen is 004.000.015//004.003.008 as per the attached image.
Any help would be appreciated,
Brian
  • PM8000
Tags (2)
  • pm8000
Mehran_Mehrnia
Champion
Posted: ‎2024-03-07 12:21 PM . Last Modified: ‎2024-03-07 12:22 PM
1
1840
Hi @BrianW
Could you check meter's 'General' tab using ION Setup to see what firmware versions are running on both meter and Remote Display(RMD)?
Here is an example for ION9000:
If RMD firmware is 4.0.15 as you shared, and if meter's firmware version is lower than V2.1, then they are not compatible and meter needs to be upgraded first.
Depending on PM89RD96 troubleshooting icon displayed(page 8/8 on the following upgrade document), the recommended action is required:
Here is the link to "Upgrade PM89RD96 display firmware to v4.0.15" document:
https://www.se.com/ca/en/download/document/7EN72-0202/
Best Regards,
-Mehran
L3 Expert technical Support Specialist
Mehran_Mehrnia
Champion
1
1840
Hi @BrianW
Best Regards,
-Mehran
BrianW
BrianW
Contributor
Posted: ‎2024-03-08 01:26 AM
Thank you very much Mehran for taking the time and providing a good solution to the issue. The issue is no repaired just in time for our FAT!
My best regards,
Brian
